1 - 4 of 4 Posts
2013 / 2014 Mercedes Benz CLA 45 AMG 4Matic Specs / Specifications / Technical Data
Basic data
MSRP starting from
Engine and performance
Cylinder arrangement/number
I4
Total displacement (cc)
1991
Net power (hp @ rpm)
[email protected]?
Net torque (lb-ft @ rpm)
[email protected]?
Compression ratio
Acceleration 0-100 km/h (s)
Approximate top speed (km/h) [2]
Fuel and emissions
Fuel tank capacity/with reserve (L)
Fuel economy, city (L/100km) [3]
TBD
Fuel economy, highway (L/100km) [3]
TBD
Drag coefficient
Power transmission
Drive configuration
All-wheel drive
Transmission types
7G-DCT automatic transmission
Manual transmission gear ratios
Automatic transmission gear ratios
Final drive ratio
Dimensions & weights
Wheelbase (in/mm)
Overall length (in/mm)
Overall height (in/mm)
Overall width (in/mm), including mirrors
Turning circle (m)
Trunk capacity (Max/Min) (L)
Curb weight/payload (kg)
Maximum gross vehicle weight (kg)
Maximum roof load (kg)
Towing capacity (kg)
Wheels
Front tires/wheels
Rear tires/wheels
There is no official press release available at the moment, but the 2.0-liter, 4-cylinder turbocharged engine is expected to deliver 360 HP (265 kW) at 6,000 rpm and 450 Nm (332 lb-ft) of torque between 2,250 - 5,000 rpm. Power is transferred to all four wheels through a dual-clutch, seven-speed transmission with Race Start function.
It should complete the 0-62 mph (0-100 km/h) run in 4.6 seconds en route to an electronically-limited top speed of 250 km/h (155 mph). The Mercedes-Benz A45 AMG is expected to have an average fuel consumption of 6.9 - 7.1 liters / 100 km and CO2 emissions between 161 - 165 g/km.
There has been a press release on the Daimler media site for hours now, that details all of that stuff.
1 - 4 of 4 Posts
