· Vendor
Located in
2pcs 2Gen Projector Laser LED Door Welcome light Step Shadow Logo Lights LED
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
Dear .when you order pls notice me logo number .thanks!* Note:* The project is suitable for all vehicles* Please note when paying in your car (such as Mercedes-Benz*or 001)* 1.If you need this Laser lamps in different logo for other car model,* Please refer to above*and tell us what car model you like or let us know the number after you buy it,* Thank you! So sorry that we can not offer the other logo couldn't found above. 2. If you would like to use in 4 car doors, you need 2 pairs. 3.*Large wholesale is available.** * * ** Specifications 1?Voltage: DC9-32V 2?*Philp 7W led chip 3?*Working temperature:* -40°C~105°C 4?Dimension: 3.5*2.4 cm 5?Power Cable Length: 1.5 m Product Features 1?Most popular in USA 2?Leading the trends of car lighting sources 3?No Pollution,no noise,no electronic interference 4?High efficient and energy saving 5?High power LED Installation*steps: 1.*take*apart*the*door; 2.*drill*a*hole*at*the*bottom*of*the*door*cover*with*a*augar; 3.*Put*the*light*in*the*hole*of*the*door*cover; 4.*Adjust*the*lamp*holder*to*the*best*position.Tighten*the*fixed-screw*at*the*bottom*of*the*light*cup,Connect*the*power*cord*on*the*door 5.*Put*the*door*cover*fitted; 6.*Installation*is*complete.* Attention: 1.We strongly suggest installing this product by Professional Automobile Modify Factory or Workshop. The manufacturers disclaim all responsibility for belongings or personal casualty caused by improper installation or misuse. 2.Our company does not responsible for the legality of installing this product,please* confirm with the vehicle management department for the record* before installation 3.Please access*the positive and negative poles of the power through voltage regulator** rectifier. Do NOT direct access to car battery.
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
