Hello, I have a big problem. I am from Bulgaria, I apologize for my English. I bought the car a week ago and noticed a big problem. At a speed of 30-40-50 miles, when reduced, I have a scraping grinding sound from the front of the car, from the left side or somewhere in the middle. At first I thought it was from the tires or the brakes. I bought new tires, we checked the brakes, the bearings on the hubs, the axles, cv, everything on the suspension is strong. Then we lifted the car on a hoist, started and drove it, found noise that most likely comes from the front differential. There is no noise in the back, only in the front.
Do you have any idea what the problem is? In Bulgaria, this model is not very common. The car is 47,000 miles. I will be very grateful if you help me with information from your dealer or experience. I am very sad, I have had the car for 5 days . If someone like , i can give you the VIN - nomber.
I buy the car from USA , New York with with small demage on the rear side,
Thank you again
Discussion Starter · #3 ·
We solved the problem. Broken front left bearing. Now everything is perfect.
Thanks !
