1 - 19 of 19 Posts
Let's talk about these frameless doors. It seems to be quite the selling point according to the sales brochure, but in my opinion it just seems like filler.
Wouldn't a door with a frame be stronger and also more weather resistant? Do all models have this frameless door feature?
Just wondering...
when the doors are open and windows are down, frameless doors look better, so when it comes to MB buyers that are look for more than just a car to commute, things like this probably does matter more to them just because of how it looks for one. I bet there are more reasons.
Most 2-door coupes have frameless doors. With the CLA being a 4-door coupe I guess it makes sense to have frameless doors also.
I do not have any experience with them, but ya to me a door with a frame would be stronger.
Also on the frameless doors (at least on the CLA) the window automatically drops a bit when you open the door and then closes when the door is shut. You don’t have the frame to create any type of seal for wind or noise, so I am assuming that’s what it’s done for.
What happens in places like NH in the winter and you come out to your car which is an ice cube and the windows are frozen shut???? Someone out here must have more info....
Also on the frameless doors (at least on the CLA) the window automatically drops a bit when you open the door and then closes when the door is shut....
Do you know for a fact that it does that? I've had 2 cars with frameless doors and they open and close just fine without needing the window to be lowered a bit.
From the owner’s manual page 77
i When a door is opened, the side window on that side opens slightly. When the door is closed, the side window closes again.
! The side windows will not open/close if the battery is discharged or if the side windows have iced up. It will then not be possible to close the door. Do not attempt to force the door closed. You could otherwise damage the door or the side window.
How did you get a hold of the owners manual already? Is there a link?
you hear a loud crack when the ice breaks.
I've always been weary of this wearing down the regulator over time.
problem with frameless windows is that when the window arm and parts that keep it in line start to wear down, the window will start poke out causing some annoying leaks. At least when this happens with a door that has a frame, you don't have to keep on adjusting the window every time you open the door.
Discussion Starter · #13 ·
Did this actually happen to you with a car you own?
i like the automatic window adjustments. anyone who's had to re-align their windows/rollers after freezing weather understands how annoying loose windows can be. but ya, i'd be worried about this in extreme weather conditions..and what about theft? are frameless doors easier to break into?
I don't know. I live in NJ where we get our share of blizzards and I've never had any issues with frameless doors on either of the two cars I had with frameless doors. I guess if you do a good enough job of scraping the ice off then you don't have to worry about ice build up. Also, I don't see how frameless doors would be more susceptible to theft compared to doors with frames. If you break a window you break a window. Having frames or not isn't going to make a difference.
you do have to be more persistent with scraping the ice off in the winter or when you open the door you always hear the ice braking off.
It really only happens during ice rain and wet snow followed by freezing temps.
We get plenty of those, too.
1 - 19 of 19 Posts
