1 - 10 of 10 Posts
Discussion Starter · #1 · (Edited)
Here is a pix of my cla250 lowerd on stance. We are working on the rear. Thanks jason! Wheels look damm hot!. All members should check out getyourwheels.com if your looking for wheels an tires. Here a quick pix of the front lowerd.
Way too low for my taste. Besides, at that height I'll be scraping it all day.
I had BONOSS wheel spacers 20mm on my car for almost 21,000 miles, with no issues whatsoever.
Maybe you can try what I installed.
They can customize the thickness and data that I want, so that I can install new tires with different data, and the customization time is very fast, just 1~3 days.
They have aluminum alloy 7075-T6 and 6061-T6 options. 7075-T6 will be more expensive but better in quality. In fact, 6065-T6 is good enough. Its tensile strength, yield strength and elongation can support our normal use. And its lugs are grade T10, studs are forged grade 12.9.
If you need it in the future, this is their case article.
1 - 10 of 10 Posts
