New Design MB SD Connect Compact 5 has an equivalent function as MB SD C4, this text is about the way to program Mercedes W246.
Diagnostic software: March 2020 Xtentry
Model series: B(242 246)
Vehicle model designation:246 242
Engine:270 910
Transmission: All
The diagnostic process begins:
*The Progress has 5 steps
*The condition is recorded
*The control units are being initialized
*Check of VIN
*The Coding of the control units is read
*The emissions-relevant data are out from the vehicle
Click Repeat, and then repeat the operation until the fifth time when you click Repeat, the selected system software will be automatically updated
The status of the ignition cannot be read out from the vehicle. The current ignition status of the vehicle must be set manually
Note: Continuing the procedure without switching on the ignition can lead to faults or errors in the procedure...
MB SD Connect Compact 5 supported car list
Passenger Car Support List:
A(176), A(169), A(168), B(246), B(245), CLC(117), C(204) C(203), C(202), 190(201), E(212), E(211), E(210), 124(124), S(222), S(221), S(220), S(140), S(126),
E(207), CLK(209), CLK(208), CLS(218), CLS(219), CL(216), CL(215), CL(140) SLK(172), SLK(171), SLK(170), SL(231), SL(230), SL(129), SL(107), SLS(197),
M(166), M(164), M(163), G(463), G(461), E(212), E(211), E(210), 124(124), S(222), S(221),S(220), S(140), CLK(209), CLK(208), CLS(218), CLS(219), CL(216),
CL(215), CL(140), SLK(172), SL(231), SL(230), SL(129), SL(107),SLS(197), M(166), M(164), M(163), G(460), GL(164), GLK(204), R(251)
Van Support List:
MB 100(631), T1, SprinterIII, SprinterII, SprinterI, Sprinter900, Citan, Vito(639), Vito(638), V(638), Viano(639), T2, Vario, Vaneo(414)
Truck Support List:
Actros963/4, Actros2,3, AtegoIII, AtegoII, AxorII, Eonic, Zetros, Actros, Atego Light, Atego Heavey, HPN M96, Atron, HPN M2000, SKL, FSK, Further model series
Unimog Support List:
U20, UGN, UHN
03.2020 MB SD Connect C4 Software Problems and Solutions:
http://blog.eobdtool.co.uk/03-2020-mb-sd-connect-c4-software-problems-and-solutions/
Engine:270 910
Transmission: All
*Check of VIN
Van Support List:
Truck Support List:
U20, UGN, UHN
