2010 Mercedes-Benz C-Class Luxury C 300 AWD 4MATIC
for the new model vehicles, such as W223 W206, you cannot do diagnosis with xentry like the old model vehicles. you need login online to do diagnosis and delete fault code. but with our getobdtool solution, you can do diagnosis without login.
Q & A
1. Can I do online scn coding with this solution?
—- No, after we process your xentry software, you can do diagnosis with xentry, but cannot do online coding.
2. Can you do w222 ism coding
—- No, w222 ism coding need online, you can not do it.
3. can we do a w223 Head light module coding?
—–cannot, it can not do online coding, can only do diagnostic, delete fault code
4. Is it Possible to work with xentry, and do codings with dts monaco?
—– Yes, you can do diagnosis and delete fault code with offline xentry, then offline coding with DTS if you have coding data.
5. And Xentry works?
yes, but can only do diagnotic, delete fault code, can not do coding, you can do offline coding with DTS if you have coding data.
xentry only for diagnostic, and dts monaco for codings
6. it’s just for xentry? Can work also with DTS Monaco ?
Yes, it’s just for xentry. we won’t process your dts and monaco software.
7. What’s diagnostic tool supports?
—– Since W206 W223 all have DOIP protocol, you should use some the test equipment which support DOIP function, such as Original VCI, Original ecom, C6, C4 DOIP….
8. Everytime need process when i use xentry to do diagosis?
No, only need process 1 time, then you can use it for 1 year.
9. Is it for 1 time use?
—– No, after we process it, you can use it for one year.
10. How do I get the crack file?
—– We will crack it for you.
11. in which xentry version can you make the crack ?
2022.06 version software.
12. can enter and delete fault code without login ?
Yes, after we processed, the interface will be as below, no need login.
13. Can I sale it to my clients?
—-Yes, we will give reller for a better price after you pay 2 solutions.
14. How many minutes you need to process the software?
Arround 10 minutes.
16. How can I buy this solution?
—- Please make sure your xentry software is 2022.06
—– Please make sure your diagnostic tool is Original VCI, Original Ecom, C6 or C4 DoIP
—– Please contact us from below send teamviwer for us to process the software.
