Question: Does Autel IM508 with XP400 support the same function as Autel IM608 for Mercedes EZS?
Eobdtool.co.uk engineer replied:
Yes. The IMMO software they support is the same. But IM608 comes with XP400, and IM508 comes with XP200. Once Autel IM508 works with XP400, then it can support the same IMMO function as MaxiIM IM608.
Check the differences between Autel IM508 and IM608:
IMMOIM508IM608
Smart Mode (Guided and Automated Key Learning Function)
Auto Detect Make/Model/Year/System
Read PIN (All Keys Lost)
Key Learning
IMMO ECU Reset/Adaption
IMMO ECU Refresh/Coding
Remote Learning
AUDI Q5/A4/A5 2015-2017 Key Learning
VW MQB Key Learning
BMW FEM/BDC Key Learning and Adaption
BMW CAS4 Key Learning and Adaption(+XP400 Yes)
Mercedes Key Learning(+XP400 Yes)
2015-2018 Land Rover& Jaguar Start Key Writing(+XP400 Yes)
Volvo Smart Key Learning(+XP400 Yes)
Programming
EEPROM Read/Write
MCU Read/WriteBasic
Key Programming
Mercedes Infrared Key Read/Write
Remote Frequency Detect
OE-Level Diagnostics
All Systems for Over 80 Makes and Models
OtoFlash (J2534 ECU Reprogrammer)
Advanced Service Functions
Oil Service Reset
Parking Brake Pad Relearn After Replacement
Steering Angle Sensor Relearn
Battery Registration and Reset
Diesel Particulate Filter Regeneration
Tire Pressure Monitoring System
Active Test
ECU Coding
VW/Audi Component Protection
Complete Service Functions
Tool Features
Built-in Rechargeable Li-ion Battery5000 mAh15000 mAh
Internet XP datableWi-FiWi-Fi
Multilingual SXP port5000 mAh
Limited One Year WarrantyWi-Fi
Touch screen7-inch10.1-inch
Memory32 GB64 GB
ProcessorQuad-core processorHexa-core processor
Camera8.0 Megapixel
Resolution1024×6001920×1200
Here is the Autel IM508/IM608 IMMO function list for Mercedes-Benz top car models:
worldwideIMMO function list
Car brandCar modeladd keyall key lost reset immobilizerreplace IMMO components engine/
immobilizer
/for blade key)/
(smart IMMO box
/for smart key)
IMMO backup
(smart key)
delete keylive data
/DTC
MercedesC-Classadd keyall key lostrepair hopping(this function is for after complete key programming, car can’t not be started)EIS/EZS replacement
(read,erase/write
/clear TP protection/
activate/back up
/write code)
engine(read, erase/write/
activate/back up/write code)
ELV(read/erase
/write/clear TP protection
/activate/sync)
disable
/enable key
E-Class
S-Class√(1999-2005 some support all key lost)√(2005-)no ELV
AMGno ELV
V-Class
More info about Autel IM608 and IM508:
Autel MaxiIM IM508 Plus XP400 Key and Chip Programmer Support Same IMMO Function as Autel IM608:
Autel MaxiIM IM508 Advanced IMMO & Key Programming Tool Plus XP400 Key and Chip Programmer
Autel MaxiIM IM608 Diagnosis IMMO Key Programming with XP400 and J2534 ECU Reprogrammer:
[UK Ship] Autel MaxiIM IM608 Diagnostic Key Programmer and ECU Coding Tool
FacebookTwitterEmailShare
