· Vendor
Located in
NEW Bonnet Hood Strut Shock Damper Subaru Impreza WRX STi GC8 Ver.3-6 97-00
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
AutoFittings Item Specifics Placement on Vehicle : Front Car Type : Subaru Impreza WRX GC8 Year : 1997-2000 Country of Manufacture : Taiwan Color : Matt Black Bonnet Hood Strut Damper Kit Subaru Impreza WRX STi GC8 Ver3-6 97-00 Type *Hood Damper ( Gas Filled ) Colour *Matt Black Note *ROHS Approval* Application *Subaru Impreza WRX STi GC8 Ver.3-6 97-00 What is included *2 x Damper*Unit *2 x Mounting Plates (set)* *1 x Instruction Manual* *(As seem in the photos, Serration nuts*are included for some vehicle models) What is inside * Hood dampers use the same technology as many shock absorbers. These gas filled struts can hold open a substantial load, and then telescope closed when needed. While many new cars come with hood dampers, they tend to wear out over time requiring replacement. * Older vehicles on the other hand can be updated with hood dampers to make engine work a breeze. In addition to OEM style dampers, there are also several companies who produce custom hood dampers so that you can add a little flash to your engine bay and retain great function. This is the perfect modification for the budget minded enthusiasts who wants to improve functionality. * AutoFittings High Quality Gas Filled Hood Damper Alu. Fittings Brake Fittings Fastener New List Item BMW Z8 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Mercedes-Benz SLS AMG Wheel Spacer Adaptor 8mm thick 5x114.3 5x120 5x112 USD 19.99 Honda Pilot Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 Toyota MR2 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 BMW 1600-2 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Mercedes-Benz ML430 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Mitsubishi Montero Sport Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 USD 19.99 Suzuki Verona Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 Mazda B2000 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 Kia Sephia Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 Daihatsu Charade Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 BMW 650i xDrive Gran Coupe Wheel Spacer Adaptor 8mm thick 5x120 5x112 USD 19.99 NEW Bonnet Hood Strut Damper Kit Fit For Nissan Tiida Latio Versa 04-10 4/5D USD 48.00 Scion tC Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Audi RS5 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Mercedes-Benz CLA250 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Suzuki Samurai Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 BMW 320i xDrive Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 NEW Bonnet Hood Strut Shock Damper Kit Fit For Nissan Altima L32 07-10 2D Coupe USD 48.00 Mercedes-Benz E430 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Mitsubishi Cordia Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 USD 19.99 Audi allroad Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 5x120 5x112 USD 19.99 Mazda 323 Wheel Spacer Adaptor 8mm thick 5x100 5x114.3 4x100 5x120 5x112 USD 19.99 Mercedes-Benz Sprinter 2500 Wheel Spacer Adaptor 8mm thick 5x120 5x112 USD 19.99 QR Code Shop Cat. ?*Store Home *? *Fuel Hose *?**Nylon Braided Hose *?**PTFE / Teflon Braided Hose *?**Stainless Steel Braided Hose *?**Aluminum Hard Hose *? *Swivel Reusable Hose End *?**AN4 *?**AN6 *?**AN8 *?**AN10 *?**AN12 *?**AN3 *? *AN / NPT Adaptors *?**AN to AN *?**AN to NPT *?**AN to M *?**NPT to NPT *?**NPT to Barb *?**AN to Barbed *?**M to Barb *?**Other *? *Brake Fittings *? *Banjo Fitting *? *Bulkheads & Nuts *? *Flare Plugs and Caps *? *Flare Union *? *Fuel and Gear Filter *? *Fuel Delivery Adaptor *?**Toyota *?**Subaru *?**Honda *?**Mazda *?**Mitsubishi *?**Fuel Delivery Adaptor Kit *? *Hose Finisher *? *Hose Separator / Clamps *? *Metric *? *Port Plug *? *Push-On Hose End *? *Quick Release *? *Tee Pieces *? *Tools & Wrench *? *Weld Bung *? *Y Block *? *Toppier *?**Automotive **?**Adjusting Screw Nuts /Grommets **?**Automotive Tools **?**Blind Rivets **?**Car LED Light **?**Car Wiper Blade **?**Door Lock Cilps **?**Extruded U Nuts /Foldover Nuts **?**Hole Plug **?**Hood Stand **?**Plastic Fastener / Rivet **?**Plastic Retainer **?**Push Mount Wire Ties /Zip Ties **?**PVC Plastic Washer/O Ring Seal **?**Routing Cilps / Seperator **?**Spring Clamps **?**Others **?**Steel Retainer *?**Electronics **?**Cable Tie and Mounting **?**Coaxial Cables **?**Nylon Cable Gland **?**Nylon Screws, Washer and Nuts **?**Spacer Support **?**Wire Connector *?**Home **?**Clamps *?**Industrial **?**Stainless Steel Washer **?**Aluminum Alloy Washer *? *Bosch 044 Pump & Parts *? *Fire Sleeve *? *Hose Joiner / Connector *?**Aluminum *?**Brass *?**Plastic / Nylon *? *Hood Damper *?**Cherokee *?**Citroen *?**Ferrari *?**Ford *?**Honda *?**Infiniti *?**Isuzu *?**Lexus *?**Mazda *?**Mitsubishi *?**Nissan *?**Opel *?**Subaru *?**Suzuki *?**Toyota *?**Volkswagen *? *Silicone Rescue Tape *? *Vehicle Blackbox DVR *? *Oil Cooler / Oil Cooler Kit *? *Audio *? *Hobby-Toys Payment Bonnet Hood Strut Damper Kit Subaru Impreza WRX STi GC8 Ver3-6 97-00 Type *Hood Damper ( Gas Filled ) Colour *Matt Black Note *ROHS Approval* Application *Subaru Impreza WRX STi GC8 Ver.3-6 97-00 What is included *2 x Damper*Unit *2 x Mounting Plates (set)* *1 x Instruction Manual* *(As seem in the photos, Serration nuts*are included for some vehicle models) What is inside * Hood dampers use the same technology as many shock absorbers. These gas filled struts can hold open a substantial load, and then telescope closed when needed. While many new cars come with hood dampers, they tend to wear out over time requiring replacement. * Older vehicles on the other hand can be updated with hood dampers to make engine work a breeze. In addition to OEM style dampers, there are also several companies who produce custom hood dampers so that you can add a little flash to your engine bay and retain great function. This is the perfect modification for the budget minded enthusiasts who wants to improve functionality. * Item Specifications Placement on Vehicle Front Car Type Subaru Impreza WRX GC8 Year 1997-2000 Country of Manufacture Taiwan Color Matt Black Payment Method Shipping Return Policy Contact Us We accept verified Paypal payment only. Q.How long is your shipping time? A.Item will be shipped within 2 working days upon receipt of the auction payment. Shipment normally takes 15-25 Working days to most US / AU / EU destinations. Exact delivery days varies by different countries. Please make sure the shipping address provided by PayPal is correct. If you don't receive it beyond 25 days , please contact your local post to check your parcel and tell us. * Q.What should I do if I didn't receive my item? A.Please contact us for any questions that about your order. We will reply your request within 24 business hours. * Q.How much do you charge for the customs? A.Import duties and charges are not included in the item price or shipping charges. Buyer needs to pay these fees if your local custom requires. Please check with your customs to determine if these additional costs will be prior to bidding/buying. * Q.What should I do if the item I receive is damaged or not working? A.Please contact us for any questions, our customer service members will reply your message within24 business hours. * We offer full refund if you receive defective item, please contact us for returning instruction.* * Return of goods is accepted within 14 days after item is received from buyer.* * You can choose money back or exchange. If stock is not available, only PayPal refund will be made. Customer is responsible for returning shipping cost.* * Returned item must be kept in good and original condition for full Refund.* * Warranty does not cover driver incompatibility, normal wear, unauthorized firmware upgrade, non-rechargeable batteries, consumable, and damage due to accidents, physical fore, water, fire, power surge, act of God, or other mis-use.* * Providing good customer service is our first priority, if you have any question, please contact us and our staff will assist you with best effort.* We normally get back to you within 24-48 business hours. * For the functional products in our shop, such as chargers, data cables, we have tried our best to ensure they function as the same as description, however the actual color and shape may looks slightly different from pictures because of the technical improvement and manufacturing variance. * Please be advised before you buy it now. * Welcome to our Autofittings*@ ebay store! Enjoy Shopping! Powered by SoldEazy Desktop Mobile Buy Watch
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
