1 - 15 of 15 Posts
I blaim it on the runflats.
There could be more sound insulation no doubt. But at this level of car it's not going to have E or S class like sound isolation.
It also depends what roads you are driving on as well.
What car are you comparing it to?
The road noise level doesn't bother me. I barely notice it since I'm always listening to something when I'm driving (music, news, Howard Stern, my wife yapping).
I guess it depends on what you are used to. The CLA is so much quitter then anything I've driven in the past.
Road noise is there but no more so than what I would expect. I have a 4-door Jeep Rubicon and it defines road noise! I will say this: When I make phone calls from the integrated bluetooth system, no one can tell I'm calling from within my car. So long as the call quality is great, I could care less about a little road noise so long as the sound system and call quality are great. Hope this helps!
I hate to say it, but that is called the placebo effect.
Nitrogen does have benefits. The nitrogen molecules are bigger than oxygen molecules in air so it is less likely to leak or not leak as much. Also, for those running on steel rims, you don’t have to worry about rust. Moisture in the air can collect in the tire which can rust steel rims and erode rubber from the inside. That’s not an issue with nitrogen. Check out this article: http://www.ehow.com/list_5805736_benefits-nitrogen-tires.html
When I ordered my camper a few years ago it came with nitrogen filled tires. It’s not a fad or hype. However, I never heard claims of it running quieter.
Tony,
My post didn't say there are no benefits, but for a STREET car, they are negligible. And don't forget that the "cheap spread" is 50% nitrogen anyway.
Thanks for backing it up I have been using nitrogen for a while and actually notice a difference especially with temperature changes the pressure inside doesn't flucuate.
1 - 15 of 15 Posts
