TurboKits.com CLA 250 Turbo Upgrade - $1495.00
Mercedes CLA 250 Turbo Upgrade for 2014-2019 Mercedes-Benz CLA 250 2.0T, A 250, GLA 250, Infiniti QX30
TurboKits.com is pleased to release our CLA 250 (C117) Turbo Upgrade. Constructed of billet aluminum, our 59mm compressor wheel is 5-axis CNC machined and flows 36+ lbs/min of air. Peak HP & Torque gains are in the 80-100 WHP range but this isn't just about peak numbers. The power band continues to grow up and beyond 4500 RPMs where gains approaching 125 Wheel HP and Wheel Torque can be seen. This turbo spools like stock, creates great power and pulls all the way to redline! And we've done this all while maintaining a margin of safety for the motor, transmission.
The CLA250 is a great daily. However lacking on power. Even with a Stage 2 package the factory turbocharger is "tapped" out. The lack of packages and attention to the CLA250 can put a damper on modifying. This is why TurboKits.com has spent a lot of time coming up with a turbocharger upgrade that will give the CLA250 a stronger powerband without the sacrifice of losing low-end power. Which is something overlooked by competitors.
After spending time working and collaborating with AMR on this fun project, we have finished developing a software upgrade to complete this full package and give your vehicle the "worry free" power increase you've been looking for.
Because we start with a factory CLA 250 Turbocharger, there are no custom oil or water lines to leak, simple R&R install, no headaches. All factory lines, gaskets, fittings, couplers and connectors mount to the TurboKits.com Turbo Upgrade.
Key Features:
5 Axis CNC Upgraded Compressor Wheel for More Flow
Upgraded 11 Blade Turbine Wheel for More Flow
Ported Exhaust Manifold for More Flow
Ported Exhaust Housing for More Flow
Upgraded Wastegate Actuator
Rebuilt with new bearings and balanced for smooth operation
100% Bolt on installation
+80-100 Wheel HP / +80-100 Lb Ft of Wheel Torque
Supported Platforms:
2014+ CLA 250 FWD & 4Matic
2014+ GLA 250 FWD & 4Matic
2013+ A250
Turbo Specific Tune Required. Select the AMR ECU Flash Option for a plug n play experience - $899.00
*** These gains were done on 93 octane.
*** Available for 91 octane as well.
The price listed does not include a core charge. You have 2 options 1) Pay the core charge, the TurboKits.com Turbo Upgrade will ship to you, an RGA# and shipping instructions are sent for your core return. Once received, the core is inspected and your account will be credited upon approval. Or 2) Do not pay the core charge when you place the order. We will send you a RGA# and shipping instructions for your core to be sent in, it will be inspected, approved and given the TurboKits.com treatment, then shipped back to you. There is no core refund with option 2, as no core charge was collected. Thank you.
Key Features:
2013+ A250
