I have the basic Audio 20 with the usb. I have read the manual and checked the USB extensions. I am not sur what is going on but when I play music through the USB it will skip tracks. Same music recorded off the same CD with the same .mp3 extension. Is any one else seeing this and if so what am I not catching. I have read the manual about the structure needed. It is formatted fat32. Anyone else have this problem? Next stop is back to the dealer if I can't find a soulution!:confused:
I used a 32Gb USB with 100 mp3 and folder with over 20 mp3 and I haven't encounter any problem. Are you plugin the USB directly to the USB port or you are using a USB extension ? I read you cannot use any adapters or extension.
